Help with 2011 Saab 94
sbedx4
Post by sbedx4 »
Hello everyone, I need some help and I hoping if anyone has any ideas if they could help. I have tried some other forums and had no luck. I have a picoscope but I did not realize that my scan tool software had similar graphs. I had a p0018 and p0019 with sometimes a p0300 misfire code. I have attached .csv file with more information and a few images that show graphs not run. Easier to pull all the information from the software i have. I can add more images, if we need and from picoscopr. I had changed the engine, timing, OCV valve, and sensors and a lot of other tings, but i still have these codes. Not sure what could be wrong or if these tests not running are causing the issues. I have been reading the case studies and trying to understand the graphs. Hopefully you guys may have an idea that no one else has been able to solve. Thanks
Saab Test Data.csv
(263.26 KiB) Downloaded 262 times
